Variable Power Supply Control
jenk00001
Jul 2022
South Carolina
Hello,
I am currently working on a project that requires the equipment to vary DC power output during cycle. I need to vary from ~30VDC to ~90VDC. Using a Compact Logix controller but havent seen any ethernet IP programmable power supplies out there. Anyone have a similar application or ideas? Thanks in advance.
Jenk
Welcome to the PLCTalk forum community !
The most obvious solution is a PSU with an analog reference like 0-10V or 4-20 mA, and an analog output channel from an analog output module.
What is the purpose of the variable PSU voltage ? Is there a feedback loop or is this just a set-and-run open loop application ?
This will be powering a battery operated tool and needs to simulate varying voltages while the tool is undergoing the main function of the machine which is a dyno. I saw a few power supplies with analog inputs but was hoping there was a unit out there to communicate over ethernet.
We have some Magna-power electronics supplies here and I just did a quick look up on their site and it appears they have what you're looking for.
I can also say at a previous employer we used a ton of Delta Electronica supplies for 12V automotive related testing. These had a profibus interface, and were definitely not a high maintenance item, but they were probably 10-15 year old design, so I would guess without looking them up that they probably have ethernet options these days.
Friends, I need advice on how to design and power up 26 Variable Frequency AC Motor Drives in an electrical room with 480 volt power available...
6,275
Hi All, Hoping the community here can help as I'm new to PLC programming. The project I'm working on is using a Micro850 2080-LC50-24QBB and...
1,737
125
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
74
dear all.. i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump The pump data...
177
