variable speed ac motors
The thing about those standard 'variable speed' controllers people often refer to, is that they don't vary speed directly, they only change the supplied voltage. They come in different shapes like variacs or electronic controllers with triacs or even IGBTs. And this works great with blowers, fans, in fact, it works great with nearly all single phase motors (with running capacitor a.k.a. PSC) driving exponentially changing loads, so even pumping liquids will work over a very moderate range.
For all other load applications it's a no go! If speed has to be set way below 40Hz without significant loss of torque, or if it has to be increased beyond 50Hz, an inverter is all that's capable of doing it.
At www.invertek.co.uk (hit 'Products' - Optidrive E1') you'll find single phase motor inverters, ready to go. Those inverters all work according the same principle: The running capacitor is removed and the starter winding is fed with a (smaller) voltage that has the correct phase shift (90 electrical degrees or PI/2) at all frequencies.
I just tried to figure out a way of using standard inverters. At that time I used Hitachi a lot, so I used one of their low cost 230V types to do some experimenting.
Like I said before, removing the running capacitor (or PSC) has all to do about torque. If you connect a PSC motor to 2 outputs of a 3-ph VFD, like you normally would connect it to the mains, the motor simply wouldn't start under approx 30Hz.
If you were to connect the starter winding to the third phase but still leave the running capacitor in place, then first of all the starter winding current would not be sufficient enough, and second it would never have the right phase shift at the lower frequencies. Thus, also resulting in poor (starting) torque.
Best results were achieved by removing the PSC and feeding the starter winding directly with the third phase of the VFD. The starter winding current does not exactly have the right phase shift (120 electrical degrees in stead of 90) but at least the current level is more than sufficient to make the motor deliver maximum torque at 10Hz and up. Unfortunately this can only be done up till the frequency where starter winding current reaches its maximum permissable value. Since it's impossible to set the V/F characteristic of one output differently from the other two, I had to figure out a way to bypass the overcurrent problem. That's where I came up with the solid state relay, to disconnect the starter winding above a certain speed.
One would think that a PSC motor MUST have the capacitor (thus current through the starter winding) available at all times, but guess what: IT DOES NOT. Once the motor is running at 20Hz or more, one can easily disconnect the starter winding circuit. Under no load conditions you will notice a substantial increase in motor current (due to the power factor being worse now), but other than that the motor will still be able to deliver the rated power.
Now, I'm pretty sure I used several terms like 'way too much trouble', 'quite a hassle' and 'not worth your time', so please bear with me if someone else has some experimental genes like I do. ;o)
Never thought this would become such an issue, but then again I get the same disbelieve amongst engineers with the 'infamous 87Hz technology'. You know, using a 230V-50Hz 3-ph motor on a 400V inverter and setting the base frequency to 87Hz (50 x 1.73), thus increasing the motor's power and torque by 1.73. Lots of people have heard of it, but are too afraid of implementing it.
BTW Keith, I also have to agree that there might be VFDs not capable of handling a 2-phase load or would trip in the event of.
A Practical Test
A bit of a late reply, to say the least (!), but thank you Sparkz for at least suggesting that VFD control of a single phase PSC motor may be possible.
I recently bought a spiral dough mixer for domestic use. Unfortunately it only has one speed and a two speed version is much more expensive.
The spiral runs at 130rpm and I really wanted an option of a faster speed as well, about 190rpm.
The motor is a 350W PSC induction motor.
I picked up an Altivar 11 550W VFD off Ebay. (Single phase 240v in, 3 phase 240v out).
I started by glueing a thermocouple into one of the winding slots and fixing another to the surface of the motor laminations.
I then ran the mixer unloaded for 30mins, recording both temperatures at 5 minute intervals.
Then I powered the motor via the VFD, as per Sparkz's diagram, but I left the power permanently connected to the original capacitor winding, ie no timed disconnect.
I ran the motor at 50Hz and checked the temperature rises over time and they were no different to the original ones with the capacitor and without the VFD .
I've now got the VFD running at 45Hz for low speed and 75Hz for fast speed.
The motor is running slightly lumpy at 45Hz, but not badly.
So thing are looking good so far.
I only use the mixer about twice a week for about 20 mins each time, so this is a very light duty, without any frequency extremes.
I think it shows though, that in a "hobbyist" situation you can control a single phase PSC motor with a VFD, but I would never consider it for other peoples products or in an industrial or commercial situation.
Lance
So glad my post was useful. Even if it's taken ten years. ;-)
Your kudos couldn't have come at a better time, Lance.
BTW, I noticed an error in my post (#46): Motor torque is NOT increased when using 400V/87Hz as base voltage/frequency, only motor power.
dear all.. i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump The pump data...
158
We have an application where we need a joystick to control a VFD. Off in the center, 0-10V in forward and 0-10V in reverse. Also with auxiliary...
2,330
I have a customer that came to us, looking for a variable speed control for a 115V motor He bought a 115V vibrator. The motor is a cap start...
1,881
I need something to vary the speed of a magnetic vibrator. It's 120vac Single Phase, 60HZ, 0.5amp. Need something I could give a 4-20ma signal...
2,271
Repeat Question - Maybe to our UK friends, especially. I need variable speed control of single phase blower motors, for an OEM I work for. I...
3,625
