VB and PLC's
seppoalanen , I would like to see you write to the data registers in the plc like that. I think you are just using the plc as a pass through to the printer when you send the txt file.
zmanvortex,
InTouch (IT), some plc, a few printers with serialPort
Procedure is like this:
-PLC sends (IT fetch) ID-code (some SQL-Table's Key-code) to IT and Tag: Print Label2
-IT executes SQLSelect(..."ID="text(ID-code,"#") etc. script commands, generates tags for label and sends label contents to printer2 SerialPort.
But how easily, what I need more and why, because OS can do it but not IT. I can do it with VBasic without eny extra driver.
I have feel I repeat my self, but I don't like their way to sell drivers for nothing and I must do 'nibble virtual acrobatics'.
Your method is fine if you want to print to a printer, but we are trying to change values in the data tables of the plc, such as the Input and Output tables, Internal Bits , timer and counter presets or accumulated values, or just regular data words.
Hello, fellow PLC enthusiasts, I’m a newbie in PLC and am currently on a project that involves connecting an Omron CP1E (CP1W-CIF11) PLC to an...
40
Hello, I want to connect the Factorytalkview ME with rslogix500 to see the live response of HMI buttons in Rslogix500 ladder code . I am using PLC...
59
I have a cell with a compact guardlogix as the plc and I have three hmi's and two vfd's on this cell. I been experiencing momentary comms faults...
111
Hi, hope you doing well I am looking for SIEMENS PLCSIM equivalent in GE FANUC PLC, RX3i PLC thank you
41
Hai, I'm working on Allen Bradely PLC RS Logix 5000 V20 i tried to communicate modbus communication with AB plc and RS 232 to Ethernet converter...
63
