VB in WinCC
userxyz
May 2002
any
2,768
I have a tag called Resetbel. I want to make this boolean tag high while pressing a key...
So I made a button...
Then on press I want VB code.
I tried this:
Dim reset
reset = true
HMIRuntime.Tags("Resetbel").value = reset
but offcourse, this isn't good, any help how to link a bool ?
your code is totally messing up.I've ever use VB code,unfortunely I've forgot syntax(I always use help for syntax).
If you just want to make a pushbutton why you have to use VB code.
I think C script or normal WinCC fucntion is much easier.
If you want deep detail,plese give more detail 'bout your purposal
^_^
I tried this:
Dim reset
reset = true
Your problem is the "=" sign.
Try:
Dim reset
reset = true
HMIRuntime.Tags("Resetbel").value reset
This should work.
no
no doesn't work.
What I need is:
Make a bit high while button is pressed.
If u use direct connection, than you can write the value 1 to a tag, but, in the PLC, the bit remains high, I want a bit that is high while pressed. And no, I will not use reset in the PLC, that's not clean.
About C scripting, ... maybe an example ? I don't know C and therefor prefere VB
C scripting this is very simple.
Just to set the bit high:
On your button->mouse click event->C Action
SetTagBit("Resetbel",1); //Insert this text in replacement of blue text in function
If you want to toggle this bit on each click try something like this
int x;
x =GetTagBit("Resetbel");
SetTagBit("Resetbel",x);
//text in function
int x;
If you have any problems with this let me know
I don't have WinCC in front of me, so I didn't test this. You need to create two scripts. One for the mouse down event and one for the mouse up event for your screen object (button). You need to declare your tags first (please refer to the WinCC documentation CD it is quite good.) then write the value.
On a "press left" event, use something like this:
const YOUR_TAG = "ResetBel"
const BIT_ON_VALUE = 1
const BIT_OFF_VALUE = 0
dim oYourTag
set oYourTag = hmiruntime.tags(YOUR_TAG)
oYourTag.write = BIT_ON_VALUE
Then for the "release left" event you could use the opposite:
dim oYourTag
oYourTag.write = BIT_OFF_VALUE
You could perform a .read first before the .write to check for errors. Constants can be declared for the entire picture so you'll only need to do that once. (I consider a boolean tag a waste of an expensive tag so I would use 8-bit integers with bit filtering.)
Depending on what this function is for, why would you not set the bit and let the PLC handle the reset to ensure the request is seen by the PLC?
I'm with stplanken (and Jesper, if I remember correctly) on this one. On the systems I'm cleaning up at the moment the OPs have been programmed using mouse down and mouse up to set and clear Marker Bits. Net result, on those stations where the cycle time is creeping up to around 40 ms or more, the operators tap a button to start a process then turn away to continue something else. A short time later they notice that the process they thought they had started isn't running. Once this happens a few times they can get quite upset.
By setting the Bit from the OP and clearing it in the PLC, you ensure that the Bit is always seen.
djeez
djeez... :)
The write thing is something from VB script, Am I right ?
I'm not sure I understand what you're asking. Yes, the example I gave you is true VBScript. Place the scripts in the object's mouse events for left press and left release. Right click the button object, choose properties, choose the events tab and right-click the press/release mouse events and select the VBScript option in the gaphics designer. In the editor ou can add the CONST declarations in the picture global section so it is available for all VBScripting for all objects in the picture.
actually VB script isn't suit for simple action like changing tag data for a pushbutton.It's suit for do link other applications (excel,access,etc) or some action that C script can't do.
I quit sure that's very easy for you to use C code,if you can use VB.
Combo clearly stated he wanted a VBS solution. The fact that you need to create an object is the way VB/VBScript works, nothing wrong with that. VBScripting in WinCC is very forgiving and solution-oriented, unlike that silly ANSI C that instantly crashes your server if you forget to allocate sufficient memory for a text string. We are getting off topic.
Correct me if I'm wrong, but:
When I create a button using WinCC and go to Object properties > Events, I have the choice of:
-Action
-Press Left
-Release left
-Press right
-Release right
Now why not set the bit with the Press Left action (using direct connection) and resetting the bit with the Release Left action?
This should work and needs no scripting and should work faster than running a script each time.(at least thats what the siemens-trainer told me.....)
1st, I am with Jeebs, why use scripts to solve something that you can do without scripts ?
2nd, even if you can do it with or without scripts, like Roy says, no matter if you do it like this, it has its clear disadvantages.
And it is much worse than the 40ms cycle time Roy mentions, he probably means the cycle time in the PLC, but what about the tag update time in WinCC ? A mouseclick only lasts a few milliseconds, and a typical tag update time is 1 second (400 ms if you have set it up to be fast). So for it to work the operator has to force himself to hold the button pressed for a little while in an unnatural way.
Add to that there are many things that can go wrong, so you risk that the bit never gets reset.
I have gone away from that because I have been burned.
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
72
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
61
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
75
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
78
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
153
