vb link omron plc. please help
common
Guest
C
I want to link vb with omron PLC cpm1a to get the DM value from PLC. I m using the method as stress in the manual read the DM method for example @ooRD0000000157*(CHR$(13)) to get the DM0 data from plc. But, still unable to get the data. Does anybody tried this???? pls help me.
Either this is a typo or you are using lower case letter o instead of numeral 0. Other than that, your syntax is right.
Here is the preferred syntax for the command string.
"@00RD0000000157*"+CHR$(13)
Attached is sample code.
I had a trainee, and gave hime the instruction to solve this. I have helped him a bit with this. It was very simple, there was an OCX file from Omron. I'm not quit sure if it came from Syswin or from CX-programmer. If you have this and inserted in you VB program it's very easy to use. There was a help integrated. Try the net for a search of this OCX !
To Jay Anthony
how to read ALL IR register inside OMRON plc using VB..what character reply..and how to separate it to make it use in VB..please help me..can I used @00MS43* to read all the IR status
Hey guys. I recently added a barcode scanner to our network. I can see the device through network configurator. When trying to set up the tag...
1,630
Please help me too link 2. OMRON PLC with GSM modem's. I nead too read data with each other on request. Can somewhone do dat. I apologi with may...
3,518
I need the details of the host link command :MB . Can anyone help me ? Thank you !
4,484
I come from an AB background. My current job has a lot of Omron devices. We have a couple systems with NX102's with numerous IO link devices...
655
Dear colleagues, I've made a couple of projects with Omron PLCs, still, I can't figure out a quick solution to this one. I have a CJ2M-CPU32...
2,377
