Vb.net 2015 and opc
achille
Mar 2012
CASABLANCA
Hello everybody
i must develop an application with vb.net wich will communicate with opc server ( rslinx or kepserver ) have anyone already try it or have the code for that
thanks
So here are a couple options:
1) Use an OPC server which can be complicated to program and will cost for every run time. You can see an example of what it takes to read a value here in this thread:
http://www.plctalk.net/qanda/showthread.php?t=97862
2) You can use AdvancedHMI, which is a Visual Studio solution, that has a native driver for the ML1100, only requires one line of code to read a value, is much faster, and does not require a run time license nor a development license. Here is a quick example of how to read a value in code:
Dim value as string=EthernetIPforSLCMicroCom1.Read("N11:0")
Depending on what your objective is, you can build complete HMI's without writing any code. The fully functional base package is completely free.
HI archie
thanks a lot,i downloaded advancedhmi and its working perfectly with the driver Ethernetipforslcmicrocom1.
have you any idea about communication using schnedeir modicon m340 plc ??
Hi I'm trying to talk to a SCADAPAck 334E via modnet (citect). The channel does show as online in the main kernel window but in the unit kernel...
2,510
Hello guys i'm working with an s7 1200 plc with an ET 200S expansion module. The problem is that i can't find the plc when searching in the...
36
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
27
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
59
Anyone have a idea of what would cause a failure of all nodes (buckets) of an AB Device Net MCC upon a power cycle of the main feeder for that MCC?
315
