VB Script in MP270B, little help needed
userxyz
May 2002
any
2,768
Hi
I made 2 I/O fields and I connected Tag_1 and Tag_2
Then I wrote this in Script_1:
Dim Mitsu = Int
Dim S7 = Int
Mitsu = SmartTags("Tag_1")
S7 = SmartTags("Tag_2")
Mitsu = S7
I want the value of Tag_1 connected with the value of Tag_2.
I'm doing this because I have 2 connections on this panel, one to a mitsubishi and one to and S7. So I want a connection between the PLC's of 1 tag via the panel.
But the code doesn't work, for you vb script spcialists, this must be easy ?? I don't know anything about scripting, this is the first I'm writing
greets
script
IN MP370
Step1
Create a tag s7 (internal tag of type UInt)
Also create another tag mitsu of same type
Step2
Go to scripts and make a script named “s72mitsu”
In the name field in the properties of this script type “s72mitsu”
Under type filed select Function
Lastly in parameter field type “s7” and press ADD button
Under script body u just need to write
S72mitsu=s7
Step3
Go to properties of s7 tag
Under event CHANGE VALUE select the script s72mitsu
Step4
In any screen make two IO fields
To one field attach the tag s7 (input)and to other IO filed attach the tag mitsu(output)
You are done
Not sure.
Maybe try to change
Mitsu = S7
to
SmartTags("Tag_1") := S7
edit: Actually it is a good question.
"How to write values to the connected PLC via Scripts".
If manmeetvirdi's code work, then it could be easy.
Step3(step 3 procedure in last post was incomplete)
Outputvalue-->mitsu(tag)
s7-->s7 (tag)
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
81
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
70
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
122
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
128
Hi All, I'm keep getting double quotes in between selections rather than the beginning and the end. Here's the script and please help to find...
818
