VB6 & Lenze Drive with Profibus
Loztos
Apr 2010
Juarez
17
Well, i'm trying to communicate with a Lenze drive (an 9400) from a PC. It has a profibus card installed (PBpro-PCIe from softing). The main problem is a have no experience using profibus, i spent a whole day trying to communicate with the drive without results.
I'm using a basic cable with only the needed connections (pins 3, 5 & 8), without terminators.
Attached are the GSD file for the drive and the source code in VB6 supplied by softing
Hello, I'm trying to solve a problem. The visualisation is done by VB6. How can i figure out wich databit in S7 is linked to wich variable in VB...
1,543
im doing some coding in vb6 and i have an error in this line : Dim myOPCServer As New RSiOPCAuto.OPCServer it gives me this error when compling...
2,305
Good day all. I have a SLC500 that is controlling an air flow rig. The HMI is a PC using a home-made program using VB6. I have no experience with...
4,487
does anybody have an example of how to connect to a 90-30 ge fenuc plc with the SNP-X protcol through visual basic? i have seen something on this...
1,889
G'day there, I want to send real time data to a VB6 application. It works in excel thanks to a previous response from member - plastic, but I...
3,807
