VBS problem, arrayproblem in VB-Script... WinCC Flex
userxyz
May 2002
any
2,768
Dim i, a(10)
For i = 0 To 9 Step 1
a(i) = SmartTags("visuf")(i)
Next
For i = 10 To 2 Step -1
a(i)= a(i-1)
a(0)= SmartTags("valuetag")
Next
SmartTags("visuf")(i) = a(i)
Next
This code doesn't work, only tag visuf[0] changes...
What could be the problem. I can compile it, shifting just doesn't work...
What I want is Fifo
a(i)= a(i-1)
Next
Should this be For i = 10 to 1 Step -1
For i = 10 To 1 Step -1
a(i)= a(i-1)
Next
Hi
Thanks for your help...
But, now my index 1 also changes.
current code:
Code:
Dim i, a(10)
Next
    a(i)= a(i-1)
Next
Next
a(i)= a(i-1)
Next
a(i)= a(i-1)
Next
I am not following you.
After the looping, you get this. For i = 10 To 1 Step -1
A10 = A9
A9 = A8
A8 = A7
A7 = A6
A5 = A4
A4 = A3
A3 = A2
A2 = A1
A1 = A0
You then move your incoming new value into A(0).
Fifo
This is Fifo, but when I run the script, index 0 and 1 are becomming the same new value...
A10 = A9
A9 = A8
A8 = A7
A7 = A6
A5 = A4
A4 = A3
A3 = A2
A2 = A1
A1 = A0
I wrote a small program in Visual Basic and used your code with the modifications I mentioned. Everything shifted correctly.
After the looping, your new value comes from "valuetag".
The very last loop statement would have took the old A(0) and moved it into A(1). When i is equal to 1.
a(i)= a(i-1) = a(1)= a(1-1)
Found it
Dim i, a(10)
Next
a(i)= a(i-1)
Next
Next
has to be:
Dim i, a(10)
Next
a(i)= a(i-1)
Next
Next
It may not be written in the for next loop.
I wrote: Historian 'Schrijf vorige batch weg naar de csv historian 'Wegschrijven van de vorige omdat eventueel gewijzigde parameters...
1,646
Hello, I just started learning WinCC V8.0 3 days ago, so I'm still new to how everything works in this program. I've created a pop-up with a...
684
Hello. I am trying to do some basic file operations (move file from one folder to another, rename file in the new folder etc) and usually I just...
2,189
Hello everyone. I'm trying to export data to excel from Wincc. My code is global action that executed every second that create excel filer per...
5,735
Hi all. I am trying to write vbs code to copy data SQL from one server to another . i can write data to blockdata, but i cannot copy data from...
1,668
