Versa Max micro controller connection problem.
soontat
May 2011
KUALA LUMPUR
I'm using versa max micro controller in model IC200URD64/164. Just encounter this problem. Usually i'm use Proficy Machine Edition to program it by port 1. But today can not connect it. Even I restart it again and again. But it still can use to communicate with other GSM modem, because I use port 1 as GSM modem communication. Any idea to solve it?
Thanks & regards.
This is my first post over here.
What do you use port 2 for? May I suggest that you set up a port for the GSM and a different one for programming/troubleshooting?
However, if it worked in the past, ask yourself what changed?
Thanks for your reply.
My port 2 is use for SCADA access. So have to connected 24 hours to a PC. That why I have to use port 1 to do programming and GSM modem connection. Actually I didn't do anything for this, I finded this issue was after come back from weekend holiday. Before that only use for testing, didn't change the setting and didn't change the baud rate. Do you think the codes will effect the port? or this port already spoil?
Have you checked to ensure that your computer com port has not been changed? Right click on "Target" go to "Properties". The Inspector dialog box will open up. Scroll to the bottom to Physical Port.
Detail, Details, AND MORE DETAILS.
On port 2 what protocol?
On port 1 what protocol?
If either answer is SRTP, that is the port you need to use for programming.
Thanks GTreece,
My laptop port setting
19200
old
none
My PLC Traget=> Properties=>Inspector setting
Baud rate 19200
stop bit 1
parity odd
Any error for these setting?
Regards.
Port 2 use http protocol, connect by IP address. use for SCADA.
Port 1 use for 2 purposes. That are programming and GSM modem and using modbus protocol. Is it 2 purposes useing for port 1, until it problem. But previously is fine for programming and GSM modem connection.
Regards.
Tested with supplier, he said and confirm port 1 was spoiled.
Wondering why easy to spoil? Other part woking fine, only port 1 problem.
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
158
I am new to this forum and tried posting a question earlier but did not se it in your listing. I have been trying to print report for a Versa Max...
1,454
Can any body please tell me what is the software required to communicate with Ge-Fanuc Versamax IC200UDD110-BF
1,443
Hi Im trying to fire modbus RTU command (read coils 02) when im processing the commreq im getting status word value 524.Im using PLC...
1,780
Hi I have IC200ALG430 analog mixed module, when I have connected I am not getting its reading. Is there any setting? to do? or any link of its...
2,159
