Versamax to vb.net???
gofast505
May 2004
Colorado
I am looking to try to communicate vb.net to versamax I/O via a versamax ethernet card, does anyone know of any companies that sell a OPC driver or control to enable this communication?
Bl
I've got a server from Kepware running, haven't had any problems with it yet. You can download it and run it for 2 hours at a time I think without a license. It also comes with VB examples, but they are VB 6 examples, not .Net
There is a link to the site in my first post.
Hi 505,
IndustrialDotNet.com/Products.htm will get your client side working in a few minutes. Really! Free to try, too.
Mark
Thanks for the suggestions, I also found SoftwareToolbox has a solution too, now to decide which one to use, I will post my decision later.
Happy Coding.
bl
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
441
Good evening, during the download program on a IC200CPUE05 VERSAMAX, after returning the necessary information in the set tempory IP address,the...
3,197
Good Afternoon All, I have been tasked with controlling 3 SVX9000 VFD's with the OPTC7 option board through a devicenet network using a GE...
1,885
Hello: I need to connect around 120 remote GE FANUC Versamax Ethernet controllers (CPUE05) to Cimlicity HMI using internet connections. the...
1,927
Hi, What's the best way to communicate bt versamax micro plcs using ethernet? I have 6 of them and one as a master . I tried using modbus tcp but...
1,620
