VersaPro Documentation Files
bluenoser337
Apr 2003
Nova Scotia
391
Hi: I am new working with VersaPro (usually AB and Siemens). I have a number of folders full of GE projects but none appear to have the program documentation when I open VersaPro. Are there specific files in the project folders where the documentation might be (wondering what extensions to search for). Also, is there a way to turn the documentation on and off within VersaPro? Thinking it might be there but I just haven't got it displayed? Thanks!! RB
Are you lacking both the rung comments and the reference names/descriptions, or just the text of the rung comments? It was all too easy in VersaPro to lose the text of rung comments.
If that is what happened you will see text like "COMMENT0", "COMMENT1", etc for each rung comment. Unfortunately, I don't know of any way to recover from that condition.
It is possible that whover created the files simply uploaded the ladder logic from the PLC and never had the original programmer's documentation. Open the variable table to see if there are names and reference descriptions for addresses other than %S. If they exist there is a way to define what is displayed in the ladder window, but I don't remember what it steps you need to take to change it. If you don't see any documentation in the variables window there is no point in looking any further.
Hello: I have located another copy that has I/O descriptions in the variable table that appears at the bottom, but those descriptions don't appear in the ladder diagram. Is there a way to display the text in addition to (or instead of) the address? Thanks!!
I have a LM9030 program that is running on a IC693CPU331 that was installed in the mid 90's. How can I find out if this cpu can handle newer VP...
1,278
I have a Versapro project file for a Versamax PLC. Need to identify what type of variables are suitable and made available for BMS system to...
1,712
I was given a file with a .SwxCF extension. Can this be opened in any way with VersaPro? I only have version 2.0 Pro and have no luck. I think...
1,957
I have GE Fanuc VersaPro 2.0 software where can I get an upgrade CD. I need to program a IC200UEX164 64 point (40) 24Vdc In; (24) Relay Out; and...
26
2,229
Needing a bit of help on some GE Series 90-30 configuration files. It appears that I need the GE VersaPro software at a minimum to view the data...
2,426
