Version and Article Numbers
Meyers Mills
Dec 2019
Accra
37
Hi
I downloaded a trial version of Tia Portal and very eager to create offline projects.
The problem is ,when choose 'create new project ' and give my project a name.
Under ' configure a device ' one needs to select type of controller ,specify version and article number .
I am finding it difficult typing in the version and article No. When I type it doesn't appear on the screen.Because of that, there's no general properties in project view, help!
The basic and extended instructions are also not visible in project view, how does I access the instructions in project view.
I am using TIA Portal for the first time
Help
You shouldn't need to type part numbers in directly; I generally expand the tree to find what I'm looking for.
The basic and extended instructions should be in the instructions tab on the right side, once you add a CPU. They won't be visible until then, as they change depending on which CPU family you're using.
It sounds like you're getting stuck at Step 0. There are a lot of youtube videos available showing how to get started in TIA, I'd recommend trying some.
Hi MK42,
Many thanks for your support, I managed to find my way out of it thanks.I didn't have to type it in, I'm grateful ...
Welcome to TIA Portal, expect that this kind of thing will happen often: the software is powerful but therefore the interface is similarly complex and non-intuitive. So as a beginner you will find your way more by luck and by clicking than by using intuition.
I believe the way to do this is to navigate down the [Controllers] tree that is to the left of the text and selection boxes that you are trying to fill in.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
155
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
178
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
89
