VFD Speed Setpont via PID loop problem
TimD
Aug 2007
New Hampshire
235
Hi, I have AB PowerFlex 400 drives set up on DeviceNet. I use MOV blocks to sent an int value of 0-60 to my drive and the drive happily responds, etc.
Now I set up a PID loop. I have covered all the bases (AI scaling, setup) and in AUTO, the loop responds the way I want it to, by moving the drive speed up/down in proportion to SP.
Only problem is, my drive does not react.
The output of the PID block sends 0-16733 and I am using two (I am sending information to two drives in 'sync') so I put two SCP blocks and scaled my out to 30-60hz. the out of the scaling block writes to O:4.5 and O:4.9 just like my old MOV code did.
The drives start at 30Hz and stay there, even though the out of the scaling block is writing 50 or so Hz to the drive input.
Anyone have any suggestions? Please and Thanks.
tim
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
160
Working on 2 VFDs for two motors, they follow any speed command when local and in hand. Once I try to give a Speed reference from my PLC they both...
2,206
Hello, So I was asked to turn up the speed on a VFD to allow a carriage to move a little bit faster and avoid getting stuck. Im not sure the exact...
742
I'm trying to figure out how to read the actual speed reference value from the move blocks, writing to a DB that is being sent to the VFD. For...
2,634
I don't understand how vfd detects speed when we are running in open loop control (sensorless). For me only possible way; during auto tuning it...
2,666
