Oh, I just remember one detail that I found irritating with AB PF70 VFD's. I control the drive via a network card, and there is no separate power supply to the network card or the control electronics. Thus cutting the power on the input side promptly triggers a bus fault as well. So it would seem that AB in principle expect a contactor to sit on the output side.
On Siemens MM4 VFD's the network card has a separate power supply, so in stead of a bus fault, you can get a meaningful error message "No input voltage". So it seems that Siemens in principle expect a contactor to sit on the input side.
edit:
Found a picture for Siemens MM4 with the contactor on the input side.
edit:
