Vibration/ shock sensors
locotumbler
Jan 2013
Otsego, MN
98
I have a system I am using a vision system on. It fires an air cylinder to stamp off a part. I have been asked by my Quality Manager to verify I don't exceed the MFG spec on G limits. I have never been ask to detect this. Anyone have a lead on what kind of sensor or meter I may need to detect this?
Thank you in advance.
First !!
you must nail down what you want !
dot every I and cross every t, and no i'm not joking!
second, you must be good in math and have a plc that can do the math.
Kiesler makes an accelerometer that we used to measure force.
I wasn't involved with that project but that is what I know, I was pulled off the
project and put on an automotive test line instead.
maybe others with more experience can chime in.
kames
I have a vibration logger that i mount first, just to see what kind of vibration i am up against, you need to have a good idea about G, Acceleration and Sequence, before You will be able to buy the correct sensor.
I prefer fast acting sensors with a voltage output, wired directly to my PLC, there are many different suppliers of vibration/acceleration sensors, but ones you have the data for what sensor you need, it is just picking one whit a good reputation and good service :)
the logger sounds like exactly what I am looking for. can you share the make and model of the unit you use?
By logger I believe he is speaking of the sensor he uses to log the data. Do a search for velocity transmitter or accelerometers. A physics book might be helpful as well. Similar story as above we have an application but I was not part of the development.
IFM, Allen Bradley and I am sure many others make these types of sensors.
attached and highlighted is the spec I am concerned with recording to ensure I am exceeding it.
This would be a simple task with a vibration logger, you can set it up to log every 50 msec op to an 90 minutes, I think that would be enough to show you the vibration the camera is exposed to.
Hi all! I have an application where we have a industrial trailer (ie: connected to a commercial truck / cab). The trailer will have some...
1,184
Good Morning , I know Banner has some nice wireless monitoring systems , does anyone know of any other systems that monitor temperature ...
3,518
I have a Bentley Nevada Velocity sensor that claims to spit out a 100 mv/IPS signal. I'm being told that it will work with an analog input card...
7,032
Vibration sensor that is food-grade rated. Customer is looking to monitor the vibration on their submersible pumps. These pumps are at fresh...
1,881
My customer has a small train to carry products around in their plant. The system is old and sets up some vibration as it rattles down the track...
2,146
