Dood
I have a Bentley Nevada Velocity sensor that claims to spit out a 100 mv/IPS signal. I'm being told that it will work with an analog input card (Siemens S7-1200 13-bit AI), but I'm not sure where to start with this one.
Datasheet for the velomitor is here:
https://www.bakerhughesds.com/sites... Piezo-velocity Sensor Datasheet - 141633.pdf
The AI Card is capable of 0 - 2.5/5/10 Volt signal, but how would I even calibrate it if there is no upper limit. Looking for a little guidance if anyone has experience trying to bring a 100 mv/IPS signal into a PLC.
Thanks!
Thanks!
