drbitboy
Would my PV in my PID be the rate of my constant feeder or the rate of the feeder im controlling with my PID?
The latter: the PV in the PID will be the measured flow rate of the feeder controlled by the PID.
C and D are hi: their rates are measured (Fhi); their vibrators are controlled directly via HMI; they have no PID.Okay,
Think of it as Station A, B, C, and D.
A and B have small peanuts
C and D have large Peanuts.
All stations have a bag on them to start. I set which stations are to match at the HMI. And I can control what percent each station should run at.
Station A and C will start to run either 10 and 90 percent or 20 and 80 percent. Can even go up to 30 and 70 percent.
Station C will run out of peanut much sooner than station A. So C runs out, and the program switches to station D to continue running large peanuts while station c gets a bag change. Then D runs empty and switches back to C.
Same thing for Stations A and B.
So say I am running at 12,500 with one vibrator at 60 HZ. That is just large peanuts so if I want an actual 90/10 ratio of large to small. I would need to take 10 percent of 12,500 and add it to that 12,500 and that would become my actual flow I want to reach?
I am just not sure how to create a scale factor and adjust the speed as needed on my smaller vibrator to speed up or slow down as needed.
I am pretty sure @Cody is doing this already:Things that come to mind:...
Although the large peanut bag will be set to run at a given speed maybe it would be better to use the loss in weight from that bag to control the small peanut PID,
To get 10% small peanuts in the bin, the only issue here is the details of the math, i.e. the small peanut rate should be calculated as one-ninth of the available measured large peanut rate, instead of being calculated as one-tenth of the total rate because that total rate is neither directly available nor measured.So could I just look at it this way. If I run the larger peanuts at max speed 60 hz and always keep that constant. I can calculate my flow after running for a minute by taking my weight loss.
