View Designer AOG & PopUp
Grant_PLCs
Nov 2019
Ohio
Hello All,
I'm looking to create an AOG that has a navigation button to a popup embedded within. However, the tags and values of the popup will depend on the instance of AOG. I haven't found a way of passing the AOG parameters to the PopUp.
This is possible in FactoryTalk through global objects and parameter lists.
Any suggestions?
Hi I'm working in Studio 5000 View Designer V9. The HMI panel im currently using is a 5510, whit physical buttons and functions keys on both side...
189
Question for those who are in the know how Studio 5000 works/compiles under the hood. The laptop that was supplied to me is now full with no...
592
I'm using Studio 5000 View Designer 7.01 and I'm trying to make a generic popup with bindings to properties or aliases. Basic aliases by right...
455
Hello, We are beginning to use the View Designer software for the newer Panelview 5500 and 5300 HMIs. I one we are starting with is the 5300 10"...
1,231
I am trying to reduce the number of values behind the decimal point on the HMI. The values it is reading are "REAL" values from the PLC. I am...
1,127
