Vijeo and Modbus ascii
Clevername
Oct 2009
NY
36
I'm trying to use a Schneider HMI to communicate to a PC machine that uses serial modbus ascii. The driver for the PC was created in assembler and written in house.
If I load a new driver in the IO manager for Vijeo there is only:
Modbus RTU
Modbus Plus
Modbus TCP/IP
and a few others.
Has anyone used a 3rd party driver or how should I handle this?
My options are:
1)Have our engineer write a new driver for Modbus RTU (which he said he will do no problem)
2)Use another HMI
3)I see there are some sort of gateway adapters, maybe one of these could go from ascii to RTU?
If I go with a Schiender PLC to handle it the help file in CodeSys shows all sorts of commands for modbus, but man I'm confused as hell using the read\write commands and function blocks. Even the examples have me just staring at the screen for hours..
Send halp!
You could use something like a Redlion DSPLE000 Gateway. It should be able to do a protocol conversion between Modbus RTU and Modbus ASCII.
Redlion also do an HMI which has the same protocol capabilities.
Modbus ASCII is really rare. I have not come across it in all my years in the automation business.
I was using EM6400 energy meters with Vijeo Citect scada in Modbus RTU network & mapping as following successfully. NAME- KW_SMS_1 TYPE- REAL...
2,490
Hi, I'm facing a problem in sending data to a Modbus RTU Device through the vijeo citect interface. I guess I estabilished the connection...
9,868
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
33
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
203
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
202
