Vijeo Citect 7.4 edit logo
euler13
Nov 2015
Cairo
Hi All,
Kindly I need your help to add my company logo to be displayed in a project created with Vijeo Citect Struxureware 7.4. the project is based on "sxw_style_include" starter project. the logo should be appear in all the project screen. In other words, I want to find a way to edit the upper bar of the screen template which belongs to the starter project.
You just need to find the relevant template and edit it to your liking, most things are based around the normal template in the include projects.
Just be aware that if you ever upgrade then this project will be overwritten so if you are going to edit standard include projects its better to copy it and rename it to your own projects then edit at your will
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
71
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
490
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,689
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
900
Hi everybody, I have a simple question for anyone who knows.We cant try because system is working and we dont have a permission about it. We have...
739
