Vijeo Citect %MD0 address
rolf.viktor
Jul 2012
Iasi
Hello guys
I need some help. I want to setup the address in Vijeo Citect to read data from %MD0 (for a TWIDO PLC) but I don't know which is the right one. I read here that the address 412288 is OK for %MD0 but I can't read data. In runtime mode show me #BAD.
Please help me!:confused:
Hello guys
The addrees you want is 400000 or 400001 (dependng on the driver you selected) and you want to set the data type to LONG. if that dosn't work try 40000 or 40001
Chris
Help
By the way, I have one question. Is there any limitation to address in vijeo citect. Because I only can assign variable tag of string with address S510. But when I start to assign at S511 and above, it says unknown error. what happen?
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
44
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
489
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,687
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
898
Hi everybody, I have a simple question for anyone who knows.We cant try because system is working and we dont have a permission about it. We have...
738
