Vijeo help
Clevername
Oct 2009
NY
36
I'm using SoMachine with Vijeo for graphic displays. I'd really like to put a pdf or some parts of the manual of our machine onto the display. Our Rep and Schneider say this is possible but I've had no luck displaying a pdf.
I'm also having issues displaying any mpeg or MP4's. In vijeo the error is always "format not supported". I have the resolution correct and the format but still no go.
Any help or Ideas?
Go to the help file and look for hardware features the multimedia of your specific xbt you are using. this will tell you if youre model supports the features you want to use
Ah, thanks. I'm using a xbtgt6330 and from what I see it's all supported. I'm just not sure how to display it.
I am Mohua, an application engineer at Schneider Electric.
With XBTGT6330 , it supports a multi browser platform which supports the following types of documents:
HTML (.htm) ,JavaScript (.js), JPEG (.jpg), GIF, PNG, CSS , not PDF
Only the magelis iPC (industrial PC) series support the internet browser and supports the following types of documents:
Excel (.xls) ,Word (.doc),Power Point (.ppt),Adobe Acrobat (.pdf),HTML (.htm),Video files (any file supported by the video player's codec)
But you could display a text file (saved as unicode format) with the 6330
Vijeodesigner -> target -> Environment -> Text
2. For Video the 6330 doesn't support video files. The 6340 does.
You could find more information on the Vijeodesigner online help file under - Hardware Specifications
Have you been informed about the Schneider application engineering group for assistance ?
Hi first time posting on here. I was wandering if anybody knows how to solve a problem I have with the Magelis XBT-R410 HMI. The problem is I keep getting a message saying DIALOG TABLE READING IMPOSSIBLE. I have the HMI connected to the Schnider TeSys T, everything works alarms etc but it still shows this message. On occasion it crashes and the unit has to be switched on and off to get it working again, any help would be much appreciated.
Thanks Drew
You can download the XBTN,R manual online .
http://www.global-download.schneider-electric.com/85257849002EB8CB/all/6F770D674860E191852578710074E659/$File/33003962_k01_000_03.pdf
Attachment depicts the reasons for the dialog table issue.
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,684
Hello guys, I am new in this PLC programming and currently working in a smart chiller system that used Vijeo Citect 7.4. Now, my supervisor ask...
607
Hi i developing an aplication with vijeo designer 6.2 for a generic PC. My problem is that i can't add a controller TSX p57 2634m to get variables...
1,846
Hello Everyone, I am working on an already existing project updating new equipments installed. I have no prior experience in this field but I do...
3,450
Hello I created a program in unity pro and HMI local on Vijeo Citect and communication between them realize by OFS OPC FACTORY . before the...
1,950
