VijeoCitect PLUSADO SQL functions
Marie1982
Feb 2007
House
121
I'm using VijeoCitect v7.1 with a local database Microsoft SQL Express. I make requests to that database using the PLUSADOCon.dll functions.
Here is the code that I use:
Code:
GLOBAL STRING Neptune_Connexion = "driver={sql server};SERVER=DELLVMXP\SQLEXPRESS;Database=mydatabasename;UID=sa; PWD=mypassword;Trusted_Connection=no;";
STRING sCommande;
    INT hData;
    sCommande = "SELECT EXCLEUNIK FROM Bal_Exp WHERE EnTraitement = '1'";
    hData = PLUSADOExecute(Neptune_Connexion, sCommande);
    IF (hData < 1) THEN
        My_MessageBox("VerifExp - Erreur - " + IntToStr(hData),0, StrLeft(PLUSADOGetExecuteError(0),120),StrMid(PLUSADOGetExecuteError(0),120,120),"");
    ELSE
        Exp_CleOrdre = PLUSADOGetFieldText(hData,PLUSADOGetFieldIndex(hData, "EXCLEUNIK"),"");
    END
    PLUSADOClose(hData);
    IF Exp_CleOrdre <> "" THEN
        GetExp();
    END
It works fine most of the time but sometimes I get this error from SQL Server :"Cannot open database "mydatabasename" requested by the login. The login failed".
Anyone can help me?
Marie
I am using VijeoCitect v7.5 on Desktop having Windows-7 OS. While viewing trends, it is observed that trend is not appearing continuous and value...
552
Hi Friends, I have a Vijeocitect SCADA system with One Primary Server, One Secondary, and Two Client Severs, all running on Windows XP Pro...
2,081
Hi Friends, I'm working on a Redundancy discrepancy on our VijeoCitect SCADA, The Primary can not take over when the Secondary Server goes down...
1,289
Hello folks, i bring you a new problem to be solved.. Situation: we have 2 PLC M340, 2 PC's running 1 vijeo citect license + 1 ofs opc each. for...
1,879
Hello all, I got a call yesterday from a worker at a factory where i installed an automation sistem with a PLC M340, operated via SCADA Vijeo...
4,808
