Vintage PLC-4 Microtrol
sculliesfox
Mar 2008
Ohio
So has anywone ever seen a PLC-4? If anyone has any information on it, such as software to use, when it was made, anything would be good.
Not planning on using this in a machine, but would like to do something with it to show it off. Right now not sure it it will even power up. I did a search on google, and can not find anything on the PLC.
I've only seen PLC-4 controllers in the museum at A-B in Mayfield Heights.
Tech Support hasn't even digitized the old 1773 series user manual; you would have to get it from them directly, and they'd probably have to cast a spell to get past the dragon that protects the cave in which documentation this ancient is stored.
There was a 1770-T12 dedicated programming terminal; I know of no PC-based software that would work with the PLC-4 Microtrol.
After I posted here, I did go to the Knowlege Base and saw the that. Since it has to use a Hand Held, I really dont see any way of bringing the old girl back to life.
I also saw some referances to Modicon when doing a search, I wonder if AB used a Modicon design or partnered with them on it.
I think I will see if our AB rep has an upgrade program like the PLC-5 has.
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
440
Long ago (2006) I commissioned a machine with MoviAxis inverters and find myself back in the same facility putting in a second unit ten years on...
1,319
Ok. Getting back into this after a long absence. I look on Ebay and see all kinds of Logix 1000 family of PLCs for sale. Does this family have...
20
4,918
Yesterday I was looking over a machine tool for a customer. It is an old tool that at some time was retrofitted with an Anilam "Wizard 900"...
1,388
I have a PanelView 1200 project that was created using the DOS PDS s/w (2711-ND1). The screen contrast of the PV 1200 is almost lost. The old PV...
9,393
