Vipa cpu
eebads2391
May 2008
Stockport
112
Hi ,
We had a power loss on our degreaser machine
It is PLC controlled
The plc will not run as it has lost it's memory , and we have been told by the manafacturer that the battery is on the cpu unit and the battery is not interchangeable
They say we need to buy a new cpu unit , which comes with a new battery on board
My question is this , Does anyone know that you can or cannot replace the battery
Obviously we will lose the program that was on the plc if we attempt to change the battery , but we have already lost it
What i need to know is , before we put the program back on the plc , is it possible to replace the battery in the original cpu
I dont mind stripping the cpu unit down to find out , but i was hoping someone has experience of this model and could save me some grief
Model is a Vipa CPU 314 ST
Speed 7
Vipa 3146CF01
Thanks in advance
Vipa
Thats great information , thanks
There is no card in the plc memory slot ,
Does anyone know if you can replace the on board battery ?
how do i make sure the program is saved to memory card , once we have the program loaded back on
We dont have the original program , it is having to be re installed remotely by the manafacturer ,
Are we able to force a save to memory card or can it only be done via external access to the plc ( either modem or laptop )
Any help gratefully received
Thanks in advance
Take a look at page 54 and 84 of that manual above.
Do you have the software for these plcs? They are the same as Siemens S7-300 and will work with Siemens Step 7 Simatic Manager software and MPI adaptor lead.
Better still; have the manufacturer mail you a programmed memory card.
Regards
s.f
why not?
If i have understood ur question properly, while the CPU is on,yes.ones u load the program to the cpu u can take out the battery and replace it with another one. but u can't do the same while the power is gone.
The "battery is an un marked can , Its either a battery or a capacitor , It is soldertagged and mounted on a small circuit board
I cant swap the battery , as i'm not sure if it is possible
The German manafacturers dialled in over modem and uploaded the Plc program to us , then initialised a memory card that we installed
They say they have then remotely written to the memory card with our settings and Plc program , so that in future , in the event of power loss , the Plc will reboot from memory card
Thanks for your replies Silva
In case you didn't already know; Vipa have a UK subsidiary in Bedford. Vipa Limited, Bedford i-lab, Stannard Way, Bedford MK44 3RZ. 0845 1162055
Nick
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
Hello Friends I need to monitor a PLC Vipa. Which software and cable do i need? The upload will have the comments? Thanks in advance.
1,540
Hello all. I have trouble getting online with TIA portal V15.1 with a VIPA CPU(VIPA 315-4PN12). If I try to connect I get an error message that I...
3,373
hii friends, we do not have a source program of it. Siemens manager 5.5 can not upload its program fully because one db is big enough to stop...
2,035
Hello everyone, How the vipa cpu244 net can be get connected to pgpc by Ethernet. CPU is getting connected to its process computer but when tried...
3,873
