Virtual box and VMware Workstation 12 Player.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,324
Hi.
Currently I am at work using VMware Workstation 10, with great success.
Now, for my private use, I am thinking about using Virtual Box or VMware Workstation 12 Player (because of cost, obviously).
One thing that I worry about, is if both of these have the possibility to assign the MAC address of the real physical ethernet port to the virtual ethernet port in the VM.
I have found that when using VMware Workstation that this is critical for the success of connecting to various devices from the VM.
Anybode know ?
Hi Jesper,
From my virtualbox settings, you can type in any MAC address you want. It's just a question of whether your specific devices (routers/hubs etc.) will permit 2 computers with the same MAC address (one being your host and the other your guest in virtualbox).
Thanks for the reply.
So far I have not have had any problems with the same MAC address in both physical and virtual PCs (maybe the outside world sees them as one ?).
Now I will definitely give virtualbox a go.
Will report my findings.
Also assigning IP addresses and Device Names for devices that dont have an IP or Device Name yet ?
STEP7 uses ISO protocol for this, not TCP/IP, and I have found that for this to work, the virtual network adapter must have the physical adapters MAC address.
VM Player : no snapshots
VirtualBox: yes, snapshots
That alone makes VirtualBox a more useful choice.
Once you get it working I'm sure you'll be happier with VirtualBox.
i have a dell laptop with a real com port host OS is windows 10. Running VB 6.1.42 I cannot get the serial port to configure in VB. Please Help...
1,032
Are virtual machines dependant on the virtual box version on which it was created ?
1,543
I've been using Oracle's Virtual Box in Win10 with great success for my WinXp stuff until Oracle recommended a maintenance update to v6.1.28...
1,501
Hello everyone! I have a problem connecting to plc5. I have an old 1784 PCMK card and a new industrial laptop with a PCMK card slot. The laptop...
5,069
I am trying to get c-more touch screen software to download to a ea3-t6cl. the c-more software is running on windows 7 virtual box. the virtual...
1,506
