VM Ware Version
chavak
Jul 2002
751
I am new to VMware. Is there any particular version of it that I should target to be compatible with Rockwell or other PLC related softwares.
Thank You
Only applicable when using VMPlayer:
YES!!!
Any of the V6.xx.
Do not, I repeat, do NOT use V7 or higher.
V3 to V5 might work, but they are not as stable, or they lack some features that are present in V6.
I was thinking VMware Workstation. We are using v10 and have no problems with Rockwell or Siemens software. As far as I know there have not been any particular problems with previous versions.
But of course there is also VMware Player. I didn't think that far.
Depends on the Guest OS you want to run but unless it's very old linke windows 95 or 98 I would use the current version which is 11 for workstation and 7 for player.
Workstation 10 and 11 have much better performance than the older versions.
We use player pro 7 also with multiple tech and have zero issues with it.
Thank you guys for the replies. IT guys agreed to have VM Workstation installed, and asked me for the version.
I have been reading all the goodness of VMWare here, but didn't notice anybody mentioned version though. As of now I will only need W97, maybe XP in some days, who knows. But will never go further back.
I will specify Version 10 or 11.
Thank You
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
My PLC (S7-1200 with CPU-1212C) has now been delivered to customer site. They've asked me to do some updates to the software. I can do that on my...
21
567
Does anyone know where I can get TouchWin Edit software version V2.C.5 or above? Xinje's website is lacking. I just got a newer TH765-N display...
180
I'd like to have one of my displays tell what the firmware version is of the panelview that its running on without having to quit the application...
608
Hi all, I'm still learning so apologies for silly questions. I have developed a HMI runtime on Factorytalk View Studio V13.00. I have gone to...
3,030
