Voltage/Current regulation with PWM
lostcontrol
May 2009
NeverSayNever
1,071
Hello,
We have been asked/given a brief spec to do some voltage/current control with PWM from a PLC.
From what I can interpret, they have a supply source that has a varying voltage/frequency, and want to regulate this to our local voltage/frequency.
I have done a bit of PWM for servo controls, but never anything like this. Typically, with the servo systems I have done, it is distance & speed settings only, not a continuous system like this needs to be.
They are asking for a 2mS period on the PWM, I am pretty sure this is achievable, changing on the fly etc will be what I will need to confirm the response.
Can/should this be done in a PLC? My initial thoughts are no, as there may be devices out there that can already do this. I think that they are wanting the option to be able to manipulate the input ranges relatively easily, hence the PLC option.
I am going to try and compile a list of questions to get some more information from them, type of frequency measuring device etc, but thought I would ask here first as well, as there is always a wealth of information available.
Hi all, I am trying to program an FX-4DA but I am struggling to get anything out of the channels. The 24v supply is okay. I have attached a...
1,879
Hello My analog sensor outputs 4-20mA only. My analog PLC input sees 0-10V only. How can I make this work? I tested out a different sensor...
1,805
I'm very new to AB PLC's and very cautious when it comes to hooking new stuff up (hoping to avoid blowing up any I/O cards, haha). Anyway, we are...
2,557
Hai Everybody, I have a doubt about How to read Voltage and Current values from a multifunction meter to Allen Bradley SLC 500 PLC through RS...
3,027
Hello all experts, I am doing a project in which I have to display voltage,current and RPM of a battery operated vehicle. I need to input these...
2,953
