WAGO 750-333 I/O System
qwemx
Jul 2017
Earth
195
Hi Guys
I have two questions one is how to select the correct gsd file, the gsd file zip I have downloaded from the Wago website has 20 different folders inside each folder has a different version of the gsd ranging from version 1 to version 22.
I have installed the version 22 but in this also there are three folders
-standard
-Extended
-Advanced
I have installed the standard. after that i dragged and drop the hardware of I/O in TIA Portal
but i am unable to find the end module from the GSD standard v22 which is 750-600
GSD VERSIONS.jpg WAGO PROFIBUS DP 750-333.jpg 750-600 end module not found.jpg
hallo i am having a problem the wago module and the cpu are connected with each other and the adresses are oke. but my tia portal keeps giving me...
4,666
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
125
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
361
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
346
