WAGO 750-352 Configuration
mxm_88
Apr 2014
Perm
31
Hi everyone,
I have WAGO Ethernet Coupler 750-352 with AI module 750-491 and End module 750-600. It works.
Now I need to add 2 AI modules 750-491. How is 750-352 configurated? I have seen some videos where it's doing in WAGO Addressing Tool, but I can't find this tool..
You don't need the Wago configuration tool for couplers. Just plug in the modules and that's it.
Analog input modules will start at 30001. It doesn't matter where you put them. The 1st module will start at that address and subsequent modules higher up. For example if you put a 4 channel input module first and a 2nd module 10th the 1st module will use addresses 30001-30004 and the 2nd 30005-30008. I like to place like-typed modules together and also try to place modules with "knives" (that get their power from the main power supply) so that I don't have to add power modules.
Good luck
Yosi
Anyone ever setup a Wago 750-352 Field Bus Coupler as remote I/O to a Yaskawa MPiec controller via Ethernet/IP? I have two 750-1406 discrete...
1,764
Hello, I am using WAGO 750-352 coupler to receive data from the reomte PLC. I want to save this data on my PC. My PC can communicate with the...
2,415
Any one have any idea what would be involved is getting a 1200 to use the io on one of thease wago 750-352 over ethernet. Googling has not...
4,036
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
93
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
128
