aiki202
Anyone ever setup a Wago 750-352 Field Bus Coupler as remote I/O to a Yaskawa MPiec controller via Ethernet/IP?
I have two 750-1406 discrete input modules (16 point) and one 750-1504 discrete output module (16 point) so I have the Ethernet/IP Scanner in the Hardware Configuration of MotionWorks IEC 2 Pro setup with the following assignments:
Inputs:
- Instance = 105
- Size = 5 bytes
(size of the input process image + 1 byte for status)
Outputs:
- Instance = 102
- Size = 2 bytes
Configuration:
- Instance = 1
- Size = 0
Upon trying to download I keep getting the error message "Not supported changes in I/O group". I have tried many different combinations without success. I have already setup the IP address of the 750-352 successfully.
Thanks in advance.
Inputs:
- Instance = 105
- Size = 5 bytes
Outputs:
- Instance = 102
- Size = 2 bytes
Configuration:
- Instance = 1
- Size = 0
Thanks in advance.
