WAGO 750-833 Does it have a PID block?
Alex Pel
Feb 2004
Vancouver
145
WAGO 750-833 Does it have a PID block? We are thinking to use it as a local PLC with a few IO and temperature controller. Now we have WAGO 750-303. It was originally designed to collect data only, but now we need some local control.
I have WAGO-I/O_PRO 32 Demo version. Couldn’t find any library but on the catalog picture I saw the PID_v1 (FB). Does it come with a licensed software or I have to download it separately?
Ok. Looks like PID it is not a problem for WAGO 750-833. Still have a doubt: In general, is it good idea to use WAGO PFC for a local control? Does it have Pass-through protocol? Would I be able to see and modify the code from my office through the Ethernet – SLC Profibuss Scanner – WAGO 750-833? As an alternative we can use AB cheapest Compact or Flex Logix and get rid of the WAGO at all. My company prefers AB, but cost is an issue. And for me WAGO looks like an elegant solution.
Hi guys, I've recently bought Wago 750-833 from a second-hand seller and I have quite a problem with it. When i'm trying to login i obtain...
11,618
I have a 750-833 Profibus programmable fieldbus controller from Wago that I would like to implement as a fieldbus coupler. To do so, the manual...
4,256
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
90
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
126
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
368
