Wago 750-880 send email
loopin3
Feb 2014
italy
how i can send an email with wago 750-880 using smtp.gmail.com?
the google smtp use ssl connecction.
tank you in advance.
I wanted to do the same thing, but I don't think it is possible. the Mail Library doesn't seem to support authentication, or SSL.
on youtube look for kurt braun he made simple movie for this.
or use the oscat.de function library.
I am familiar with Kurt Braun's videos however I can't find one about email. Also the oscat network library for codesys 2 does not support smtp authentication.
I am using a 750-852 with Codesys 2.3
Library is WagoLibMail_02.lib
I found another library that seems to support authentication. However when I try to write to the PLC I get this.
Unresolved external POUs
See attachment
The problem with the unresolved POUs was that my firmware on the controller was very outdated. it was Rev 3 current is Rev 8. I had included the File Library in my project it just didn't like it when transferring.
I am still working on getting the email function to work with gmail, but I seem to be making progress.
currently using the WagoLibSecureMail library since Gmail requires SSL.
ETA:
I got it to work using the WagoLibSecureMail library.
Here is my code. Very simple but it works. See my Attachments
ScreenCapture 2015-06-05 13-49-43-001.png ScreenCapture 2015-06-05 13-50-27-001.png
ETA:
Is it still working for you? I've tried with your configuration and I'm getting 'SMAIL_ERROR: Invalid response, expecting "235 - Authentication OK " telegram' :(
ETA:
Thank you very much . It is working very well :)
I am looking for Wago target files for Codesys V2.3 but can't seem to find them anywhere anymore (Codesys V3 seems to be more prevalent). Does...
10,071
Hello, I am writing a program to collect measurement data from wago 750-495 (POWER MEASUREMENT MODULE) and then send this data to SQL Database via...
1,647
Hello, I'm trying to interface a Turck VT250 HMI with a WAGO 750-880 over modbus TCP. I'm using QViS for the Turck and Codesys for the WAGO. The...
2,483
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
124
