Turck VT250 and WAGO 750-880
Jul 2013
USA
Hello, I'm trying to interface a Turck VT250 HMI with a WAGO 750-880 over modbus TCP. I'm using QViS for the Turck and Codesys for the WAGO. The WAGO 750-880 works fine with my monitouch V806T/C. I'm running a packet capture interface between the WAGO and the network (this configuration is working fine with the monitouch HMI) and I see that the Turck HMI is broadcasting periodically its presence on the network, but Its not interfacing over modbus tcp whatsoever.
Thanks for any help in advance
Do you see the difference between the packets that the Turck sends vs. the packtes that the monitouch sends? Also, the WAGO internal registers start at 0x3000 - 412289. You should still be able to read 400001 though. I've set up this connection with various venders and have never had a problem so you'll have to compare those packets to see where the Turck differs.
Cheers,
(8{)} :) .)
(Yosi)
Good morning,
I'm actually getting no packet traffic out of the Turck whatsoever, aside from the typical ftp data during a transaction. It seems as if modbus isn't even being initialized
I have been Tasked with wiring an i/o link block to an existing machine, and use a few proximity switches and a q4x laser distance sensor to...
426
Hello Experts, I have a Turck Encoder connected to P+F IO Link master communicating over Ethernet/IP with Allen Bradley PLC in Studio 5000 v34...
728
When using Turck BL20 analog and Siemens S7 can someone tell me if the scaling in S7 is still 0-27648 (for 0-10vdc/4-20ma) or is it something...
1,841
Good Morning all, I'm wondering if there are any Banner or Turck reps that hang out on this forum. We are (as I'm sure MANY of you are) having...
1,051
Trying to turn Port 1 (C1) into an output port but I am unable to figure it out. Moving a 0 into the port configuration which is IO link without...
1,478
