WAGO MySQL.Lib
musman
Nov 2014
Munich
20
I am using WAGO MySQL Lib to connect my PLC (750-880) with SQL DB on remote server.Once I download the program, I have found that until I click on 'RUN' command/button in Codesys, PLC is not connected to DB/Server.
Why is that so? I don't want to click on 'Run' Command. I want that once program is downloaded in PLC, then PLC should automatically connect to DB/Server.
Is it possible? If yes, then how?
Look under the Target's Tab. There is a check box for on-line program change (or something to that extent.) Check that box and download once more. You will have to put the controller into run mode after that download.
Also, open the tiny door on the front of the controller. There is a slide switch in there that should be in the upper position.
Good Luck,
Yosi
I am using 750-880 WAGO Controller to send data to remote SQL DB. I have noticed that when my PLC 750-880 is connected to SQL DB for approximately...
1,797
Hi all, I'm trying to connect my WAGO PLC to multiple databases. It is currently connected to a single MySQL database using the library...
935
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
99
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
135
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
393
