WAGO Profibus Master
robbo56
Sep 2009
Bristol
Does anyone have any ideas on how to implement the following:
I would like to have a number of Wago Outstations communicating to an s7-400 using Modbus TCP. I am aware of and have the specs for the Wago 750-841. I also have a number of Profibus Slaves (Danfoss drives) which I would like to bring into the Wago Unit so I need a Wago Profibus Master module. I would then let the Wago handle the profibus comms and store the data locally which I would then send to/from the s7-400 on the Modbus link.
I cannot find a Wago Module to handle the Profibus side. Does anyone know if it exists or have an alernative solution ?
Do these Wago units already exist.... why not use the S7 as the profibus master for everything? Using multiple protocols is just adding complexity IMHO
cheers
There is a reason for my question - we are using an S7-417H system. This has redundant profibus cabling, but because our profibus slaves are not redundant i.e they have a single Profibus connection we are looking at using Siemens Profibus Y-splitters. These allow a redundant link to be converted to a single link. The problem with these is 2 fold - very expensive £1000 each and they have a bottleneck of 240 bytes approx. This 240 bytes is a limit on the TOTAL no of bytes that can be allocated across all Profibus Slaves downstream of the Y splitter. Hence I am looking at other options to acquire the Profibus data from the Slaves up to the S&-417H system. Any other thoughts on how this could be achieved ?
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
hallo i am having a problem the wago module and the cpu are connected with each other and the adresses are oke. but my tia portal keeps giving me...
4,666
Any one have expereience in hooking up WAGO I/O to a Compactlogix via profibus? Looking for program examples.
2,059
Hello I have to replace a wago module and i would like to know if their is something software to configure on the remote hardware itself or if...
3,276
Hi I have a profibus network with a CPU314C-2DP and some Wago 750 IO with a 750-833 controller to collect data. The CPU314C is used on the safety...
6,596
