WAGO Comapctlogix and Profibus
I have definitely seen wago profibus hooked up to siemens not compactlogix.
We use the devicenet wago slave and IO for our kuka and ABB robots. Used a wago ethernet-modbus over Tcp/ip to talk to a proface screen don't know but I think there is a ethernetIP module.
Better of using AB same price !
Only a suggestion.(y)
I think the machine is a Siemens retro fit.
If the original machine had Wago "slice I/O" on Profibus, it still might be easier to replace the Profibus bus coupler with an Ethernet/IP one (or anything else CompactLogix will be easy to to handle, like maybe DeviceNet).
If we are talking about Wago IP67 Profibus I/O modules rather than "slice I/O" terminals... well, then you might have a problem.
Edit: you need sst card and sst profibus configuration tool. attached the scanner the plc rack. Hook up card via serial cable
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
124
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
359
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
346
How do you set up a message block for a REMOTE IO unit? (using ethernet IP)?
597
