warning Cicode message : possible missing operand between tags
ahmed007
Aug 2019
baghdad
Hi ... Everyone*
I have this warning Cicode message :
" possible missing operand between tags"
when compile below code 👇
Code:
STRING sTagName = "EG01" ;
sTagName+"_START" = sTagName+"STATUS"
Hi ... Everyone*
when compile below code ��
Code:
I think you may be Possibly just missing the ;
sTagName+"_START" = sTagName+"STATUS";
OR TRY
TagWrite(sTagName+"_START", sTagName+"STATUS");
OR TRY
Thanks it's working .. But i faced other problem that is can not associate (sTagName) with SuperGenie , I'm tried to use AssGetProperty , AssInfo Functions as below shown :
This is Associating function's cicode with SuperGenie
Code:
Function Assoc(STRING sTagName)
Asss(-2,6,sTagName,0)
END
And this my function that need to associate sTagName with it , it's called by pressing Button at SuperGenie's page :
Code:
Function My_Func(INT iArg)
STRING sTagName = " " ;
sTagName = AssGetProperty(iArg, "TagName");
END
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
110
I am running Logix Designer v32, and noticed if I type new instruction value(s) (XIC, XIO, MOV, etc etc) into a rung without any operands/tags...
783
Does anyone know of a timer that keeps accurate enough time to close a set of contacts for 30 seconds on the first Tuesday of the month for two...
1,422
Hello. I am trying to use the Codesys function FILE.DirOpen from the CAA File library. For the eError output parameter I declare a CAA.ERROR type...
2,656
Hi, I'm getting a bunch of these warnings when I build the program in Connected Components Workbench. The program is legacy code. The program...
2,394
