Warning Popup Page in Citect
Sep 2018
Chittorgarh
22
We have a system based on Citect 7.4. and some energy meters are interfaced with this SCADA through egx300 Ethernet Gateway. I have interfaced an energy meter of generator with SCADA and I want to open a warning page without mouse click as soon as load i.e. KW of generator goes below certain limit. This warning page should be popup in popup window.
What have you tried so far?
There are plenty of ways you can do this if you search around. I would create an alarm where the condition your meter exceed what ever value you care about.
I would hesitate to use a pop up honestly as it's a real pain for the operators and you then need to have a way to shelve the alarm to get rid of the pop up. Better off with an alarm and a well thought out alarming strategy
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
110
I am running Logix Designer v32, and noticed if I type new instruction value(s) (XIC, XIO, MOV, etc etc) into a rung without any operands/tags...
783
Does anyone know of a timer that keeps accurate enough time to close a set of contacts for 30 seconds on the first Tuesday of the month for two...
1,423
Hello. I am trying to use the Codesys function FILE.DirOpen from the CAA File library. For the eError output parameter I declare a CAA.ERROR type...
2,656
Hi, I'm getting a bunch of these warnings when I build the program in Connected Components Workbench. The program is legacy code. The program...
2,396
