Wastewater pH control Deadtime
kdcui
Dec 2007
USA
386
I am trying to impliment some pH control logic on a wastewater treatment system.
We are useing 93% sulfuric acid and 57% magnesium hydroxide as the adjusting agents, delivered by pumps controled by VFDs.
First stage is coarse adjustment of the pH in a 80,000 US gallon tank, the acid or base is added inline on a recirculation path that feeds the contents back into the tank.
From there the contents can go to a 8,000 US gallon 2nd stage tank for fine adjustment. Acid or base in added directly into the tank at this point.
Both tanks have agitators.
The wastewater will vary in content and compositon, and I don't have any titration curve data for the system. I don't want to use a PID loop, but I am unsure of what kind of deadtime to expect with the amount of wastewater in the tanks and neutralizing agents that are being used (I am familliar with the chemistry, but lack actual experience implementing pH control).
Also, I am unsure of how to calculate reasonable dosing amounts. I am told there are lookup tables for this, but since the wastewater will vary is this approach still valid? Or should I calculate an average dosing amount myself?
Any suggestions? I appreciate the help.
Thanks.
Thanks.
DO you mean volume and composition OR
it will vary in content composition and VOLUME and what about temperature? Then there is BOD COD dissolved solids (TDS) suspended solids etc etc.
In my opinion you need to learn what you have. I grant you since it is waste things will vary BUT you need to know what you are controlling. You need to invest in instrumentation and a data logger for automatic recording. Your best bet is
1. start reading the utility water meter or your own plant water meters so you can get some idea of volume.
2. If dumping chemical tanks an idea of volume how often dumped pH etc etc. Dumping an acid tank and a base tank at the same time can save you lots of chemical treatment.
3. Minute by minute changes in pH -- from this you can estimate hourly daily etc.
Dan Bentler
So you can predict how much of either chemical will bring the pH to the desired level? That is a huge start.
Is this a bleed and feed process or a batch process? I don't do waste water control
Tables work. That is what we used for steam generator chemistry 30 years back. The technicians would sample and make adjustments every few hours. I would think more precise methods and continuous methods are available now. The formulas that were used to generate the table should be part of the PLC program now.
I suggest that you go through the calculations yourself so you understand the process. Then you can better describe the problem. Try some what if scenarios.
Thanks for the replys.
I should probably mentioned the system has already been designed by another company and is under construction, and we are integrating the controls.
My background is Chemical Engineering, so I am familliar with the chemistry; given a pH and a volume I would likely be able to get a rough estimate on how much of either chemical to add.
The engineer who dropped this in my lap didn't give me much info on the system, besides the P&IDs. The contents will likely be a mixture of juice concentrate, water, and CIP (clean in place) fluid, and possibly other disslved content such as sugar. The process will be continuous, but the volume of the effluent into the wastewater system will vary with time, as will the proportions of the said fluids.
I haven't done much pH work outside of a lab in college, so even if I get the chemical dosage in the ballpark, I still am not sure of the dynamics (lag time between dosage and seeing a pH change, which will vary with dosage amount, strength of the acid/base and treatment volume anyways).
To my knowledge, the system is not monitoring TDS, BOC, COD, etc. and is strictly concerned with pH. As of right now, temp and pressue indicators are field instruments and are not being sent to the SCADA/PLC. Are these factors something that I should be concerned with (will it affect pH)? There is an auto sampler, but until the system is built and running the data will not be available.
It sounds like I will need information before I code anything. It also sounds like some of this might need to wait until start-up, when I am on site.
Please note that the buffering (alkalinity) of the wastewater will play a part in how much chemical you need to add to correct the pH. Also note that, by definition, pH is non-linear.
I avoid PID when I have a process that has a long response time. Peter's solution, with field adjustable time delays, will probably give better results.
Has anyone ever used the S88 batch standard in aWastewater treatment plant? References?
2,790
Does anyone have any recommendations for a good reasonably priced 4-20mA transducer I can use with a VFD running a PID loop on a wastewater line...
3,991
I'm looking at a new position for essentially an integrator in the water/wastewater industry, and I was wondering if anyone would like to share...
23
8,466
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
53
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
125
