Weigh indicator : Ohaus make
manasi
May 2007
maharashtra
123
Hello All
I want to communicate with Ohaus make weighing scale indicator (Model - T23P, Defender 2000) with Flexi Panel (Renu Elctronics) through RS232 port in order to display the mass being measured.
Need your guidance...
Manasi
I got a Defender 3000 talking via RS232 to a PLC. The setup I used was to put the OHaus in continuous print mode.
No idea about the renu. How do you pronounce renu?
You are going to connect, at minimum, the tx and gnd pins from the indicator to the rx and ground pins of the hmi and configure the indicator and hmi serial ports to matching configuration settings. 9600 baud, no parity, 8 transfer bits, 1 stop bit should do fine. Turn off handshaking and then set up the data display in the hmi.
Not sure why you are doing it this way as an analog out to an analog in on the plc would avoid the need to parse ascii characters if you have a plc in the system.
Hello Sparkie
The existing OHAUS weigh scale is has only RS232 port of communication and there is no PLC. There will be Flexi panel HMI with built in IOs.
Can you use the 1756-RIO to read values from a weigh scale with a RS-232 port? I am looking into trying to bring in data from the weigh scale that...
1,460
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
76
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
424
Good Evening , I purchased an Avery Weigh-Tronix - ZM301-SD1 to weigh a tote. The loadcell is a FLS -250. Below is the color code and...
1,293
Typically we interface to dozens of third-party devices that have Ethernet/IP capability WITH appropriate documentation to set up a GENERIC...
38
28,897
