weigh transmitter span
SteveD
Guest
S
Guys, I have load cell connected to a display which works. I have been given a resister that I can use to span my display instead of loading up 20T. My question is where do I connect the resister to simulate the change in load cell? across signal+ and -? or exc+ and signal-? your options are Exc+ and -, sense+ and - and signal + and -
Steve D
All of the above.
Most load cells are part of a Wheatstone Bridge circuit, and the output is mV per Volt of excitation. If you are going into a strain guage sensor you need to provide a mV signal. That means you need to put your excitation across the bridge, and have the resistors sized to give you about 0-10 mV.
An easier way to go is to use a simulator that will output mV directly.
It's been a while since I've done this, but I'm sure others will correct where my memory failed.
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
114
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
446
Good Evening , I purchased an Avery Weigh-Tronix - ZM301-SD1 to weigh a tote. The loadcell is a FLS -250. Below is the color code and...
1,318
Can you use the 1756-RIO to read values from a weigh scale with a RS-232 port? I am looking into trying to bring in data from the weigh scale that...
1,473
Typically we interface to dozens of third-party devices that have Ethernet/IP capability WITH appropriate documentation to set up a GENERIC...
38
29,034
