Weintek 8102ip with s7-300 PLC
sultanahmed
Jul 2013
home
63
HI,
I want to know does MT8102ip Weintek HMI work with S7-300 CPU 315 2dp via MPI?
I saw manual of MT8102ie showing that it supports 187.5kMPI.
I am confused between 2 models MT8102ip and Mt8102ie,
both HMIs has price difference(I dont need IP Class HMI).
please see attachements
Expert opinion please advice will MT8102ip work:rolleyes:?
And what is the exact part no of the Siemens PLC ?
An S7 315-2PN/DP has MPI, Profibus and Ethernet.
An S7 315-2DP have only MPI and Profibus. If there is an ethernet CP343-1 in the rack with the 315-2DP, then the PLC is also reachable by ethernet.
Siemens CPU is 315-2DP only posibility is to connect with MPI only,there is no CP lean card in PLC Rack.
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
180
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
562
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
362
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
930
Hi guys: I'm looking for, the programming software for Weintek MT8150iE, I looked for at Weintek Website, but , I can't find it help me please AD
1,354
