Weintek EBPro Recipe
YPMaint
Mar 2023
Idaho
Hello,
I am trying to configure my recipe database. I need to be able to save a recipe by which buttons on a screen are active up to 60 buttons. Each button is directly turning on an output. How would I read all those active and save it to a recipe to be able to load again if that job is on the machine.
I am using EBPro and Codesys. Weintek cMT3072x.
Thank you in advance.
The basics of your recipe are the following:
- you have 60 bits that you want to save and retrieve from a recipe database
- you should use 4 x 16-bit words to store these bits - I do not think recipes can be done with bits.
I would have 1 screen for your actual PLC buttons/bits and another for the recipe selection, creation, deletion, saving, read from PLC and write to PLC.
I found the following document about recipes in EB Pro:
https://dl.weintek.com/public/Document/UM0/UM014005E_Recipe_Database_UserManual_eng.pdf
Hi all, I wanted a 3rd party HMI that could use faceplates and indirect addressing. And I found it! I use RSLogix 5000 and Omron Sysmac. I...
4,278
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
111
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
548
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
353
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
918
