Weintek HMI Recipe Db
oldnerd
Mar 2011
Al
94
Has anyone had any experience with a weintek HMI, if so, I have a recipe data base problem that I can not explain or fix. I was hoping someone had a similar problem so I could get some advice on what to look for and what to do to fix this.
I have a Weintek 3105P HMI, the recipe database I created has been working and I have had no problems until the customer started downloading recipes from his PC. When he called me I uploaded the recipes and ran them on my PC under offline simulation. The format on the recipe looks correct, however when I enter data into a cell that is formatted for 3 digits to the left and no digits to the right, the number look like this 1.408765e-40. I have tried everything I know to change this with no luck. I move the recipe file to csv and formatted the cells, move it back to the program, it reads correctly until you write a new value into the cell. I went through the project and made sure that my numeric input objects were formatted correctly and they were. Anyone have any ideas or past experience with this. I would appreciate you input. Thanks in advance.
WeintekHMI
I created the project in V5.02.02.001 I upgraded to V5.02.02.004 and now have V5.02.02.009 none of the versions resolved my issue. I have found that when you do a recipe command, ie: Overwrite, Add, Delete these commands are automatically assigned as 16 bit int. and you can not change them. The majority of my data has to be 32 bit floating point, I have to hold 3 decimal places for accuracy. So I do not know if I'm trying to cram 32 bit into 16 bit or how this function work because it is hidden in the software. Like I said the way I have it programmed has been work for four months and then started giving problems writing correct values into the recipe. When I first set the recipe configure file up I notice it automatically assigned 2 words to each 32 bit float input. This made me think all was ok, if it uses 16 bit at a time this to me is not 32 bit. This would be a patch to make a cheap HMI work on 32 bit processors. What do you think?
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
548
Hi guys: I'm looking for, the programming software for Weintek MT8150iE, I looked for at Weintek Website, but , I can't find it help me please AD
1,344
I'm attaching an image. Ideally, I want to display a week worth of data on the hmi, but the max seconds I can enter for the x axis second display...
805
Having some fun with a system I’ve been asked to recode. The HMI is manufactured by Weintek (EasyBuilder Pro) and the PLC is an ABB PM573. Linked...
1,022
Hi; I have Weintek HMI MT8051XE at a machine. I want to play a customized alarm sound. I uploaded the alarm sound in project and downloaded to...
1,628
