Weintek MT8071iE Ethernet port
I've bought from genius. Good company and solid delivery.
Thank you very much!
I still have the cable number in my PM's if he can't remember it. I also have the PIN-OUT if you want to make one.
I think Greg is looking for a serial comm cable not a programing cable but to communicate to his PLC's to the HMI and they are Mitsubishi's so I dont think the cable I sent you will work as yours were for the Automation Direct
Attached is the Mitsubishi Cables for the HMI's
This is the for all the PLC's they support (a lot) https://www.weintek.com/Download/PLC_Connect_Guide/eng/PLC_connection_guide.pdf
Would u have one for making the Ethernet connection cable as well
I'm trying to upload a program from the aforementioned HMI but I've failed so far. I have an EasyBuilder pro and using Ethernet cable. From the...
8,009
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
161
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
556
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
361
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
928
