Weintek slow update speed.
janner_10
Dec 2014
Tewkesbury
1,301
I am using a Weintek CMT3162x talking to a Siemens S7-1200 >v4, obviously using the Siemens driver. This is our first proper job with one.
Nothing massive, maybe 300 tags or so.
The update speed is around 3 seconds, which is slow by anyone's standards.
I am using no macros, and I have 18 tags set for global data transfer, 15 @ 5s update rate and 3 @ 0.5s, so nothing dramatic.
Although I have the fast screen option checked, when you do change screens, IO fields and toggle switches take around 3 seconds to load, it's not game changing, it's just really not a good look.
IO Fields remain if you navigate away from the screen and back, but toggle switches you have to wait the 3 seconds again.
There is nothing in the diagnostics that suggests anything is wrong.
I have either grossly underestimated Weintek and this is the norm, or something is adrift that I can't spot.
Any pointers?
EB Version is: v6.05.01.379
Can't comment on your particular model or plc combination but I have had nothing but good luck with Weintek, including some applications that used ~20 macros and~200 addresses transferred via modbus TCP/IP.
Cheers
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
66
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
546
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
350
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
915
Hi guys: I'm looking for, the programming software for Weintek MT8150iE, I looked for at Weintek Website, but , I can't find it help me please AD
1,342
