weintek with control logix 5550
cdnrookie
Apr 2013
Canada
112
So my sensors are working well, naturally I want to view the information on one of our HMI's here,
no luck with weintek support, or google searches
Can you connect a weintek MT8070ie with a control logix 5550
Has to be rs232 (only option)
let me know if any of you have worked with this combo before,
thanks
no one have any ideas? support has been no help, they pointed me to chapoter 34 in the manual which had nothing to do with my issue, lol
I believe for serial communication to Controllogix you will need a specific module.. I think it's the Prosoft MVI56E-MCM, I'm not sure though.. I've never worked with weintek, why do you have to use rs232? Is using a gateway an option?
Well, ive made small progress, the hmi seems to be communicating..... at least partially.
Used the compact logix free tags driver and the hmi is now showing the displays I want it to (as others have mentioned, they are invisible if not communicating) Seems I had to jumper 7 and 8 on the HMI end, that was not in the manufactuers pinout.
Unfortunately the display reads 0.00 when I know that the analog card is putting out a 4-20 ma signal
Keep plugging away.............
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
66
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
546
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
350
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
915
Hi guys: I'm looking for, the programming software for Weintek MT8150iE, I looked for at Weintek Website, but , I can't find it help me please AD
1,342
