well, it either going to work or make a loud boom
No Boom. well, i didn't have to turn output phase loss prevention off. I had it in constant torque w/ auto boost. changed it to constant torque and the problem went away. I think i know why, but not going to presume.
Assuming this is an Altivar ATV212 drive, the manual even warns you that the output phase loss can give you trouble with certain motors and may need to be disabled. Read the full instructions for F605.
Did you perform autotuning ?
That was probably exactly what I should have done. I was using constant torque w/ boost mode. Problem was probably that I was derating a drive, so the drive was using the torque boost based off of the default hp rating and would probably have been alright if i auto tuned.
I auto tuned, and then switched to constant torque and the problem went away. Customer wasn't in the correct mood to let me play.
Logix AOP install problem: "Either every version on this media has been installed..." Hello. I have tracked the cause of my problem in my...
2,568
Dear friends. We are using s7 400 plcs,during commissioning time data sending /receiving from one plc to another was established through...
1,906
HI We are using 4 number of heavy machines having S7 400 plcs cp442 ,i want send /receive data using AG SEND/AG RECEIVE(EITHER NET...
3,447
Hello All, Brand new G308 (Just getting redy to ship out to the customer). Powered up Today and no longer can down load using USB. 1. Unable...
3,963
Hello I need to have a code set up that when an particular output is forced in either ST or ladder in RS Logix 5000. The reason for this is I...
2,510
